Perform Feasibility, Blank Fit, and Blank Nesting analyses.
Model Setup
Apply materials, orient the stamping direction, and apply constraints.
Feasibility Analysis
Perform feasibility analyses to identify thinning, splitting and wrinkling problems during the forming process.
Publish Reports
Generate a report as a .pdf file from the results of a completed simulation.
Blank Fit Analysis
Calculate the best-fit and standard blank shape around the perimeter of the initial blank shape.
Blank Nesting Analysis
Create numerous configurations to determine the optimal material usage for the transfer or progressive die stamping of sheet metal components.
