Automatically build and configure the tools for standard forming
operations.
The Auto Configure feature is available for standard
forming operations that include a default tool set. If you modify an operation by adding
or removing tools from the default set, Auto Configure becomes inactive and the icon is
grayed out.
On an operation that you've added to your analysis, click the Auto Configure
icon:
On the guide bar, select the Build Tools option.
Click to confirm or on the guide bar click Auto
configure.
The Build tools option automatically builds the tools in your model when
you add or replace a forming operation. The tools are built based on an
automatically-identified primary tool component.
Note: In addition to the Build
tools option, Automatic tool positioning is available
in the Preferences and is selected by default. This setting automatically
positions the tools and blank in a model after a forming operation is added
and the associated tool set is identified either manually or
automatically.
