Project Browser
The Project Browser displays all open files and plots within the current session contents in a hierarchical tree.
Each session contains a project by default. A project holds a set of script files and plots. The project is listed at the top of the hierarchy.
Each script has a default folder named Files where all files that are open in the editor are listed. It also lists all undeleted plots in the Plots folder.
