Editor
Use the Editor to create or open script files for authoring and execution.
You can have as many scripts open as necessary.
  • Syntax highlighting, smart indentation, collapsible sections, bookmarking, and displays line numbers to the left.
  • Split into two screens, either horizontally or vertically via the context menu.
  • Use the context menu to move files between split screens.
  • Use the layout grid to determine how to organize the split screens vertically.
