The OML window is used to enter, execute and display the execution of Compose language commands. It also displays print command outputs generated when scripts are executed from the Editor.
Plots (either 2D or 3D plots) are created by executing plot commands from either the OMLCommand Window or inside an OML script. Plots are displayed in a dedicated area located to the right of the Editor area.
The Compose Notebook is a web-based implementation of Compose’s OpenMatrix Language (OML) into a Jupyter Notebook. Notebooks (see www.jupyter.org) are a powerful way to execute and demonstrate scripted languages.
A matrix can be accessed from the Variable Browser.
For a very small matrix, the contents are visible in the Variable Browser. However, for a larger matrix, the size is displayed there
instead. All matrix content can be viewed and edited by double-clicking on its name in the
Variable Browser. This displays the contents in a separate grid
view. Each matrix is displayed in its own grid and each grid is listed in the Project Browser, named after the variable itself. The grid views can be
deleted or hidden by accessing the context menu on the grid name in the Project Browser.
Each filled cell in the grid is editable by double-clicking on the cell. Only single
numeric values (including complex) can be entered. The matrix is updated immediately. The
matrix can be expanded in each dimension individually by selecting rows or columns and
accessing the Insert option from the context menu (new cells are filled
with zeros). Similarly, rows and columns can be deleted as well.
