Run R Scripts
R scripts can be executed like any other script (OML, Tcl, and Python) by pressing the Run button. Similarly, you can interrupt them by pressing the Stop button.
Run R Scripts
It is important to note how the R interpreter is accessed from Compose. When Compose starts, only the OML interpreter is loaded. The Python and R interpreters are only loaded “on demand”.
- Select R script. OR and select an existing
