The Compose Notebook is a web-based implementation of Compose’s OpenMatrix Language (OML) into a Jupyter Notebook. Notebooks (see www.jupyter.org) are a powerful way to execute and demonstrate scripted languages.
Interactive Usage
While scripts are running, you may still view and manipulate scripts and plots, depending on the language used.
OML, Tcl, Python, and R Scripts. Compose supports OML, Tcl, Python, and R languages. The use of the interpreter language is first defined by the script being executed.
Using Macros
You can record your session actions (in the Editor) as macros to replay them at a later time using the Macros menu.
