Altair Activate 2020 Release Notes
New Features
Note: * Indicates Business Edition of Activate.
- New Names for the Activate Editions: Business and Personal
- The Professional Edition of Altair Activate was renamed: Business Edition of Altair Activate.
- Communicate Library*
- A new Communicate block library provides support for TCP/IP , UDP, Serial and MQTT communication protocols.
- HSTPYFIT Block*
- The new HSTPYFIT block implements fit (pyfit) solutions exported from Altair HyperStudy.
- Add Documentation When Exporting an FMU*
- When exporting a super block as an FMU, you can leverage the Model Report feature in Activate and optionally issue a command to generate an .html page with information about the super block and include it with the FMU.
- Read and Display FMU Documentation
- The FMU Import block can access and display information about the FMU as an .html page (optional).
- New Tutorial: Explore Three Coupling Methods with Flux*
- Compare three coupling methods between Activate and Flux using co-simulation, lookup tables and FMUs.
- Signal Current Block*
- SignalCurrent block is added to the HyperSpice library (under HyperSpice>Analog>Interfaces).
Enhancements
- FMU Export Support for Static-Linked Libraries*
- FMUs exported from Activate 2020 are now linked statically to the required math library (MKL).
- Model Display
- The model display and navigation performance is improved in the Block Diagram Editor/Modeling Window.
- Events Reduced in Hydraulic Cylinder
- The friction model in the Hydraulics cylinder block has been reimplemented to reduce the number of events.
- Automatic Access to Parameters in the Block Dialogs
- After double-clicking a block, the block dialog opens with the focus on the first parameter of the block.
- Automatic Access in the Initialization and Context Editors
- After opening the Initialization and Context editors, you can enter text immediately without clicking in the text area first.
- FMU Block Attribute Display
- The FMU block Info dialog includes new attributes: DefaultExperiment, needsExecutionTool and generationDateAndTime.
- FMU Export*
- When exporting an FMU, information about the solver parameters is included in the file modelDescription.xml.
- Speed Unit Added to Conversion Block
- The Unit Conversion block supports a new Speed unit: (mm/sec).
- Flux Co-Simulation Available with Linux*
- Flux 2020 now supports co-simulation with Activate on Linux platforms.
- Non-Initialized Parameter Warning Issued
- The Modelica compiler now generates a warning for each non-initialized parameter.
- Support Added for VS2019 Compiler
- Support for the Microsoft VS 2019 compiler has been expanded to include Build Tools: Community and Professional editions.
- Repeat Block Available for Code Generation
- The Repeat Activation block is now supported for code generation in Activate.
- Collapse and Expand Palettes in Library Manager
- The Library Manger includes new buttons to expand or collapse the display of palettes in the tree.
Resolved Issues
- Error with discrete transfer function block for large input size.
- Copying a super block can crash the application.
- On Linux, Activate crashes when running a model using an FMU modelDescription.xml that is located in a /tmp directory that was created by root on Linux platforms.*
- On Linux, interpolation methods are not available for the SignalIn block.
- Issue with the undo operation after a copy-paste on a block is resolved.
- FMU export of nested FMU doesn't pass compliance check.*
- RLTDIR warning message when starting Activate on Linux platforms.
- When placing HyperSpice components next to a SpiceCustomBlock, the simulation cannot run.
- Crash occurs when importing a nested FMU that has been exported with a non-zero Preferred Communcation Stepsize.
- A crash can occur when an empty matrix is used as a limit for saturation in the integrator block.
- Activate crashes when running a Flux co-simulation if the current working directory is read-only.*
- Model report selection frame sometimes shifts away from the block.
- The Open File dialog for the FMU block does not offer the *.fmu file filter on Linux platforms.
- Running a Flux co-simulation on Linux should not change the env variable ALTAIR_HOME.*
- The SpiceCustomBlock should allow block names to contain special characters.
- Creating a Model Report can fail after generating the report twice.
- Cannot change the text font size in plots on Linux platforms.
- Opening the Context Editor inside a super block should not act as a modification to the model.
- Activate loses focus when closing the Find tool (from CCustomBlock).
- The CurrentSensor block is not displaying results.
- Modelica language syntax highlighting is not working in MoCustomBlock on Linux platforms.
- Spice models not compiling correctly.
- An FMU that is exported using the P-Project code generation, and is then imported, gives different results from the original model.
- The Modelica demo model LineForceWithTwoMasses.scm fails randomly.
- Undo-redo operation with Hyperspice block results in a crash.
- Mouse scroll is disabled when modifying parameters inside of the Modelica block parameters dialog.
- Issue with the initialization of some parameters when working with Thermal/FluidHeatFlow Modelica models.
- On Linux platforms, pausing a model during co-simulation with MotionSolve can crash the application.*
- Code generation with P-Project does not support matrix input with an integrator.
- If a co-simulation with MotionSolve fails, Activate is non-responsive after the failure.*
- Code generation with P-Project for an FMU with the Power block doesn't pass a compliance check.
- Code generation with P-Project for an FMU with a MatrixMultiplication block is failing with VS 2019 compiler.
- When generating a Model Report, block images might be omitted due to long file names.
- Running a Spice model with a Sparam block should not create a .rpa file next to the Activate model.
- Screen capture for the Model Report can fail on Linux platforms.
- Issue with the port position and label for the HyperSpice Sparam block has been fixed.
- FMU import doesn't support safe mode in Linux.
- In some cases, Activate crashes though the Modelica compiler errors are not detected and no warnings are issued.
- In a model report, the double-click operation to open a super block is fixed.
- The selection frame for the Model Report feature does not match the exact block position.
- Issue with exporting an FMU from a Spice block.*
- Text is not displayed in the Curve Editor when the language is Japanese.
- Pressing Enter when modifying text in the Property Editor should not move the cursor to the next property widget.
