Marine 2020 Release Notes
New Features
- Beam Meshing
- When geometry is exported from Marine CAD systems, you typically get
additional information via .xml files on the 1D lines about how the beams were
created. Beam section types, offset, material and orientations are
defined on geometry lines as attributes. Meshing these beam lines, you
use these attributes to create FE beams automatically with correct
section types, orientation and offset. This reduces the FE model
preparation time and errors.Figure 1. CAD Attribute Based BEAM Model Creation (Type, Orient, Offset)
