I/O Options and Subcase Information
Entry Used in the I/O Options section or in frequency response (direct and modal) subcases to
request particle velocity at the fluid grids.
ACPVELO (format) = option
Argument |
Options |
Description |
format |
<H3D, PCH, blank> |
- H3D
- Results are output in Hyper3D format (.h3d file).
- PCH
- Results are output in Punch format (.pch file).
- Blank (Default)
- Results are output in all active formats for which
the result is available.
option |
<YES, ALL,
NO, NONE,
SID> |
- YES, ALL (Default)
- Velocity is output for all acoustic grids.
- NO,
NONE
- Velocity is not output.
- SID
- If a set ID is given, the particle velocity is
output only for the fluid grids listed in that
set.
