AEFACT
Bulk Data Entry Defines real numbers for Aeroelastic Analysis.
AEFACT SID D1 D2 D3 D4 D5 D6 D7
D8 D9
AEFACT 5 1.2 0.2 1.0
SID Set identification number.
No default (Integer > 0, should be unique)
Di Real numbers.
Default = blank (Real)
  1. AEFACT entries should be selected by a CAERO1 entry.
  2. Embedded blank fields are not allowed.
  3. To specify division points, there should be one more division point than the number of divisions.
