AELINK
Bulk Data Entry Defines relationships between on among AESTAT and AESURF entries.
Based on:(1)
uD+n∑i=1CiuIi=0.0
Where,
- uD
- Dependent variable
- uIi
- Independent variable
AELINK | ID | LABLD | LABL1 | C1 | LABL2 | C2 | LABL3 | C3 | |
LABL4 | C4 | etc. |
AELINK | 11 | INBDA | OTBDA | -3.0 |
ID | Identification number or Character string.
(Integer ≥ 0 or ALWAYS) |
LABLD | Character string to identify the dependent aerodynamic
variable. (Character String) |
LABLi | Character string to identify the i-th independent aerodynamic
Ci | Linking coefficient for the i-th
variable. (Real) |
- If ID field is a positive integer, the AELINK entry (or entries) is (are) selected by the TRIM entry in the Case Control section.
- If the ID field is 0 or the character string ALWAYS, then the linking relationship apples to all subcases.
- The entry constrains the dependent variable to be a linear combination of the independent variables.
- LABLD data should be unique for a given ID. That is, the same variable cannot be constrained more than once.
- LABLD and LABLi refer to AESTAT or AESURF Bulk Data Entries.
