AELIST
Bulk Data Entry Defines a list of aerodynamic box IDs.
AELIST | SID | E1 | E2 | E3 | E4 | E5 | E6 | E7 | |
E8 | etc. |
AELIST | 14 | 200 | THRU | 610 | 621 | THRU | 730 | 900 | |
901 |
SID | Aerodynamic list set identification number. (Integer > 0) |
Ei | List of aerodynamic box IDs. (Integer > 0 or THRU) |
- The AELIST entry can be referenced by AESURF and SPLINEi entries. Refer to these entries for the meaning of the data provided.
- When the THRU option is used, all intermediate boxes should exist. The word THRU may not appear in field 3 or 9 (2 or 9 for continuation lines).
- Embedded Blank fields are not allowed.
