The S-N curve, first developed by Wöhler, defines a relationship between stress and number of
cycles to failure. Typically, the S-N curve (and other fatigue properties) of a
material is obtained from experiment; through fully reversed rotating bending tests.
Due to the large amount of scatter that usually accompanies test results,
statistical characterization of the data should also be provided (certainty of
survival is used to modify the S-N curve according to the standard error of the
curve and a higher reliability level requires a larger certainty of survival).
When S-N testing data is presented in a log-log plot of alternating nominal stress amplitude or range versus cycles to failure , the relationship between and can be described by straight line segments.
Normally, a one or two segment idealization is used.
(1)
for segment 1
Where, is the nominal stress range, are the fatigue cycles to failure, is the first fatigue strength exponent, and is the fatigue strength coefficient.
The S-N approach is based on elastic cyclic loading, inferring that the S-N curve should be
confined, on the life axis, to numbers greater than 1000 cycles. This ensures that
no significant plasticity is occurring. This is commonly referred to as
high-cycle fatigue.
S-N curve data is provided for a given material .
Rainflow Cycle Counting
Cycle counting is used to extract discrete simple "equivalent" constant amplitude
cycles from a random loading sequence. One way to understand "cycle counting" is as
a changing stress-strain versus time signal. Cycle counting will count the number of
stress-strain hysteresis loops and keep track of their range/mean or maximum/minimum
values.
Rainflow cycle counting is the most widely used cycle counting method. It requires
that the stress time history be rearranged so that it contains only the peaks and
valleys and it starts either with the highest peak or the lowest valley (whichever
is greater in absolute magnitude). Then, three consecutive stress points (1, 2, and
3) will define two consecutive ranges as and |. A cycle from 1 to 2 is only extracted if . Once a cycle is extracted, the two points forming
the cycle are discarded and the remaining points are connected to each other. This
procedure is repeated until the remaining data points are exhausted.
Simple Load History:
Since this load history is continuous, it is converted into a load
history consisting of peaks and valleys only.
It is clear that point 4 is the peak stress in the load
history, and it will be moved to the front during rearrangement (Figure 5). After rearrangement, the
peaks and valleys are renumbered for convenience.
Next, pick the first three stress
values (1, 2, and 3) and determine if a cycle is present.
If represents the stress value, point then:(2)
(3)
As you can see from Figure 5 , ; therefore, no cycle is extracted from
point 1 to 2. Now consider the next three points (2, 3, and
4).(4)
(5)
, hence a cycle is extracted from point 2
to 3. Now that a cycle has been extracted, the two points are deleted
from the graph.
The same process is applied to the remaining
(7)
In this case, , so another cycle is extracted from
point 1 to 4. After these two points are also discarded, only point 5
remains; therefore, the rainflow counting process is completed.
Two cycles (2→3 and 1→4) have been extracted from this load
history. One of the main reasons for choosing the highest peak/valley
and rearranging the load history is to guarantee that the largest cycle
is always extracted (in this case, it is 1→4). If you observe the load
history prior to rearrangement, and conduct the same rainflow counting
process on it, then clearly, the 1→4 cycle is not extracted.
Complex Load History
The rainflow counting process is the same regardless
of the number of load history points. However, depending on the location
of the highest peak/valley used for rearrangement, it may not be obvious
how the rearrangement process is conducted. Figure 7 shows just the
rearrangement process for a more complex load history. The subsequent
rainflow counting is just an extrapolation of the process mentioned in
the simple example above, and is not repeated here.
a load history consisting of peaks and valleys only:
Clearly, load point 11 is the highest valued load and
therefore, the load history is now rearranged and renumbered.
The load history is rearranged such that all points
including and after the highest load are moved to the beginning of the
load history and are removed from the end of the load history.
Equivalent Nominal Stress
Since S-N theory deals with uniaxial stress, the stress components need to be
resolved into one combined value for each calculation point, at each time step, and
then used as equivalent nominal stress applied on the S-N curve.
Various stress combination types are available with the default being "Absolute
maximum principle stress". "Absolute maximum principle stress" is recommended for
brittle materials, while "Signed von Mises stress" is recommended for ductile
material. The sign on the signed parameters is taken from the sign of the Maximum
Absolute Principal value.
Mean Stress Correction
Generally, S-N curves are obtained from standard experiments with fully reversed
cyclic loading. However, the real fatigue loading could not be fully-reversed, and
the normal mean stresses have significant effect on fatigue performance of
components. Tensile normal mean stresses are detrimental and compressive normal mean
stresses are beneficial, in terms of fatigue strength. Mean stress correction is
used to take into account the effect of non-zero mean stresses.
The Gerber parabola and the Goodman line in Haigh's coordinates are widely used when
considering mean stress influence, and can be expressed as:
Gerber:(8)
Goodman:(9)
Where,
Mean stress given by
Stress Range given by
Stress range after mean stress correction (for a stress range and a mean stress )
Ultimate strength
The Gerber method treats positive and negative mean stress correction in the same way
that mean stress always accelerates fatigue failure, while the Goodman method
ignores the negative means stress. Both methods give conservative result for
compressive means stress. The Goodman method is recommended for brittle material
while the Gerber method is recommended for ductile material. For the Goodman method,
if the tensile means stress is greater than UTS, the damage will be greater than
1.0. For the Gerber method, if the mean stress is greater than UTS, the damage will
be greater than 1.0, with either tensile or compressive.
A Haigh diagram characterizes different combinations of stress amplitude and mean
stress for a given number of cycles to failure.
Parameters affecting mean stress influence
FKM:
Regime 1 (R > 1.0)
Regime 2 (-∞ ≤ R ≤ 0.0)
Regime 3 (0.0 < R < 0.5)
Regime 4 (R ≥ 0.5)
Where,
Stress amplitude after mean stress correction (Endurance stress)
Mean stress
Stress amplitude
If all four are
specified for mean stress correction, the corresponding Mean Stress Sensitivity
values are slopes for controlling all four regimes. Based on FKM-Guidelines, the
Haigh diagram is divided into four regimes based on the Stress ratio () values. The Corrected value is then used to choose
the S-N curve for the damage and life calculation stage.
Regime 1 (R > 1.0)
Regime 4 (R ≥ 0.5)
Where,
Mean stress
Stress amplitude
Damage Accumulation Model
Palmgren-Miner's linear damage summation rule is used. Failure is predicted when:(10)
Where,
Materials fatigue life (number of cycles to failure) from its S-N curve
at a combination of stress amplitude and means stress level .
Number of stress cycles at load level .
Cumulative damage under load cycle.
The linear damage summation rule does not take into account the effect of the load sequence on the accumulation of damage, due to cyclic fatigue loading. However, it has been proved to work well for many applications.
