Explicit Dynamic Analysis (Radioss Integration)
Explicit Dynamic Analysis in OptiStruct is provided through an integration of the Radioss Starter and Radioss Engine via a translator. Explicit integration schemes, are available via Radioss Integration.
Transparent to you, OptiStruct input data is directly translated into Radioss input data. The Radioss Starter and Radioss Engine are then executed, and the results are brought back into the OptiStruct output module to export the different output formats.
