Response Spectrum Analysis
Response Spectrum Analysis (RSA) is a technique used to estimate the maximum response of a structure for a transient event. Maximum displacement, stresses, and/or forces may be determined in this manner.
The technique combines response spectra for a specified dynamic loading with results of a normal modes analysis. The time-history of the responses are not available.
Response spectra describes the maximum response versus natural frequency of a 1-DOF system for a specified dynamic loading. They are employed to calculate the maximum modal response for each structural mode. These modal maxima may then be combined using various methods, such as the Absolute Sum (ABS) method or the Complete Quadratic Combination (CQC) method, to obtain an estimate of the peak structural response.
RSA is a simple and computationally inexpensive method to provide an approximation of peak response, compared to conventional transient analysis. The major computational effort is to obtain a sufficient number of normal modes in order to represent the entire frequency range of input excitation and resulting response. Response spectra are usually provided by design specifications; given these, peak responses under various dynamic excitations can be quickly calculated. Therefore, it is widely used as a design tool in areas such as seismic analysis of buildings.
