ANALYSIS
Subcase Information Entry The ANALYSIS command can be used in the I/O Options section to request that only a finite element analysis be performed (optimization input is ignored). It may also be used in the I/O Options or Subcase Information sections to identify the solution sequence for all subcases or for individual subcases, respectively.
ANALYSIS = option
Argument | Options | Description |
option | <ONLY, OPTSKIP, STATICS, NLSTAT, MODES, MCEIG, BUCK, DCEIG, DFREQ, MFREQ, DTRAN, MTRAN, DFOUR, MFOUR, HEAT, NLHEAT, MBD, EXPDYN, FATIGUE, RANDOM> | These options refer to the run control functionality of the
ANALYSIS command:
The remaining options refer to the solution sequence identification
functionality of the ANALYSIS command:
- When ANALYSIS=ONLY
or ANALYSIS=OPTSKIP are used:
- only applicable in the I/O Options section
- may be used in combination with one of the other ANALYSIS options.
- all elements (including design elements) are treated as non-design elements.
- all properties and grids referenced by size and shape variables will be set at the values on the associated property and GRID data.
- If an OptiStruct optimization model has DOPTPRM, DESMAX, 0, the number of license units checked out is the same as the checkout for an OptiStruct analysis job.
