Thermal Contact Solver
Thermal analysis is performed first using initial contact status.
An iterative solution process is developed to solve fully coupled nonlinear thermal structural problem, as shown in Figure 1. Nonlinear structural analysis is employed to find contact status. Thermal conductance at the contact interface is calculated based on contact clearance or pressure, or based on user-defined values. Coupling is essential because the contact status is used to determine thermal conductance. Temperature results from thermal analysis are used as convergence criteria.
- For thermal contact problems with CGAP/CGAPG, PGAPHT is required. The PGAPHT entry should have the same PID as PGAP. For problems with CONTACT and PCONT, the PCONTHT entry should be used and it requires the same PID as PCONT.
- Thermal conductivity based on the AUTO option (KCHTC/KCHT fields on PCONTHT/PGAPHT entries) can be used in thermal analysis to allow OptiStruct to automatically determine the conductivity values based on the conductivity of surrounding elements. AUTO conductivity is chosen in such a way that it works as a perfect conductor for closed gap/contact and insulator for open gap/contact.
- For problems without PCONT, PCONTHT is not required. Thermal conductivity is internally calculated by the AUTO method.
- High conductance at the interface is automatically enforced for FREEZE contact.
- In Heat transfer analysis with Contact (except for
FREEZE contact), the slave set ID
(SSID) should not be defined as a GRID set.
Figure 1. Fully Coupled Contact-based Thermal-Structural Analysis
Theoretically, while higher conductance values enforce a perfect conductor, excessively high values may cause poor conditioning of the conductivity matrix. If such effects are observed, it may be beneficial to reduce the value of conductance, or use conductance based contact clearance and pressure.
Clearance based Thermal Conductance (TCID on PCONTHT/PGAPHT, via TABLED#)
Figure 2. Thermal Conductance based on Contact Clearance
Pressure based Thermal Conductance (TPID on PCONTHT, via TABLED#)
Figure 3. Thermal Conductance based on Contact Pressure
Clearance and Pressure based Thermal Conductance (TCID and TPID on PCONTHT, via TABLED#)
Figure 4. Thermal Conductance based on Contact Clearance and Pressure
Thermal Contact with FREEZE Status
For thermal contact with FREEZE status, the actual contact status (open or closed) based on geometry will be used in heat transfer analysis.
