APRESSURE
I/O Options and Subcase Information Entry Used to request aerodynamic pressures in static aeroelastic response.
APRESSURE = option
Argument Options Description
option <ALL, NO, SID>
Default = ALL
ALL or blank
Results are output for all points.
NO
Results are not output.
SID
If a set ID is specified, results are output only for aerodynamic boxes listed in that set.
  1. This command is supported only for Aeroelastic Static Analysis.
  2. The SET command references box identification numbers.
  3. The output is printed in the .trim ASCII file.
