BMFACE
Bulk Data Entry Defines quad or tria faces that are in turn used to define a barrier to limit the total deformation for free-shape design regions.
BMFACE BMID G1 G2 G3 G4
BMFACE 10 8203 8204 8100
BMID Barrier mesh identification number. Referenced from a DSHAPE Bulk Data Entry.
No default (Integer > 0)
G# Grid point identification number of connection points. G1, G2, and G3 are required to define tria faces, G4 is required to define quad faces.
No default (Integer ≥ 0, all unique)
  1. Grid points used in the definition of BMFACE entries cannot be used to define structural elements.
