BNDFIX1
Bulk Data Entry Defines the fixed (B-set) degrees-of-freedom to be fixed during DMIG generation using CMSMETH card.
BNDFIX1 C GID1 GID2 GID3 GID4 "thru" GID6 GID7
  GID8 GID9 etc.
BNDFIX1 12345 1220 1221 THRU 1229
C Component numbers.
No default (Integer ≥ 0 or blank). Zero or blank for SPOINT and any unique combination of integers 1 through 6 for grid points with no embedded blanks.
GIDi Grid of scalar point identification numbers.
No default (Integer > 0)
THRU Keyword to allow a range of GID. THRU can be in any field.
  1. BNDFIX1 and BSET1 are equivalent.
  2. The combination of the three ASET/ASET1, BNDFIX/BNDFIX1, and BNDFREE/BNDFRE1 are not allowed together in the same input data.
  3. If BNDFREE/BNDFRE1 and ASET/ASET1 are present, the DOFs associated with ASET will be in the B-set; except the DOF assigned to BNDFREE which will be in the C-set.
  4. If BNDFIX/BNDFIX1 and ASET/ASET1 are present, the DOFs associated with ASET would be in C-set; except the DOF assigned to BNDFIX which will be in the B-set.
  5. Multiple "THRU" sequences can be used on a single card, and can span across continuation lines.
  6. If the "THRU" comment is used, G1 and G2 must exist, but the grid points between G1 and G2 are not required to exist.
