BNDFRE1
Bulk Data Entry Defines the free (C-set) degrees-of-freedom to be fixed during DMIG generation using CMSMETH card.
BNDFRE1 | C | GID1 | GID2 | GID3 | GID4 | "thru" | GID6 | GID7 | |
GID8 | GID9 | etc. |
BNDFRE1 | 12345 | 1220 | 1221 | thru | 1229 |
C | Component numbers. No default (Integer ≥ 0 or blank). Zero or blank for SPOINT and any unique combination of integers 1 through 6 for grid points with no embedded blanks. |
GIDi | Grid of scalar point
identification numbers. No default (Integer > 0) |
THRU | Keyword to allow a range of GID. THRU can be in any field. |
- BNDFRE1 and CSET1 are equivalent.
- The combination of the three ASET/ASET1, BNDFIX/BNDFIX1, and BNDFREE/BNDFRE1 are not allowed together in the same input data.
- If BNDFREE/BNDFRE1 and ASET/ASET1 are present, the DOFs associated with ASET will be in the B-set; except the DOF assigned to BNDFREE which will be in the C-set.
- If BNDFIX/BNDFIX1 and ASET/ASET1 are present, the DOFs associated with ASET would be in C-set; except the DOF assigned to BNDFIX which will be in the B-set. Any number of continuations may appear.
- Multiple "THRU" sequences can be used on a single card, and can span across continuation lines.
- If the "THRU" comment is used, G1 and G2 must exist, but the grid points between G1 and G2 are not required to exist.
