Bulk Data Entries by Function
Guidelines for using Bulk Data Entries are listed in Bulk Data Guidelines.
The following table lists Bulk Data Entries according to data type.
Data Type | Bulk Data Entry | |
Optimization | BMFACE | DRESP3 |
Aero | AECOMP | CAERO1 |
Arbitrary Beam Section | BEGIN | CSEC8 |
Bodies | RBADD | RBODY |
Constraints | JOINTG | SPC |
Coordinate Systems | CORD1C | CORD2R |
Contact | CNTSTB | PCONTHT |
Contact Extension for Explicit Analysis | PCONTX | |
Eigenvalue Analysis | EIGC | EIGRD |
Elements | CAABSF | CPYRA |
Fatigue Analysis | FATDEF | MATFAT |
Fluid Structure Modeling | ACMODL | FSI |
Frequency Response Loads | ACSRCE | RLOAD2 |
Grid and Scalar Points | GRID | SPOINT |
Heat Transfer Boundary Conditions | CHBDYE | QBDY1 |
Includes | INCLUDE | |
Materials | MAT1 | MATMDS |
Material Extensions for Explicit Simulation | MATX0 | MATX42 |
Matrix Input | DMIG | EL2PROP |
Modal Damping | HYBDAMP | TABDMP1 |
Matrix Reduction | ASET | CSET1 |
Metadata | METADATA | |
Miscellaneous | MAP | MODCHG |
Model Checks | ELEMQUAL | |
Multibody Dynamics Entities | CMBEAM | CMSPDPT |
Multibody Dynamics Joints and Contacts | JOINT | MBCVCV |
Multibody Dynamics Loads and Motions | INVELB | MBSMNT |
Multibody Dynamics Simulations and Requests | MBACT | MBREQM |
Nonlinear Analysis | BASELIN | NLADAPT |
Explicit Analysis | ACCLR | TSTEPNX |
Non-structural Mass, Damping | NSGE | NSM1 |
One-step Stamping | BLKHDF | FLDATA |
Parameters | GAPPRM | PRETPRM |
Parts and Instances | BEGIN | INSTNCE |
Ply-based Composite Laminates | DRAPE | STACK |
Pretensioned Analysis | PRETENS | PTADJST |
Properties | HOURGLS | PDAMP |
Property Extensions for Explicit Analysis | PBARX | PSHELLX |
Random Response | RANDPS | RCROSS |
Response Spectrum | DTI,SPECSEL | RSPEC |
Rotor Dynamics | RGYRO | RSPINR |
Set Definition | SET | SET3 |
Solver Selection | SOLVTYP | |
Special Outputs | BORE | PEAKOUT |
Static Loads | ACCEL | PLOAD |
Transient Nonlinear Loads | DAREA | NOLIN4 |
Units | DTI,UNITS |
