CDSMETH
I/O Options and Subcase Information Entry The CDSMETH command can be used in component dynamic synthesis method for generating component dynamic matrices at each loading frequency.
CDSMETH = CDSID
CDSMETH = 10
Argument Options Description
CDSID <INTEGER>
Default = NONE
ID of CDSMETH in the Bulk Data section.
  1. If CDSMETH is specified, only one is allowed. The data corresponding to component dynamic synthesis will be stored in an H3D file with the name filename_CDS.h3d.
  2. The must be a modal frequency response , except it does not require a DLOAD card for load specification.
