CHECK
I/O Options and Subcase Information Entry The CHECK command can be used in the I/O Options section to request that only a model check be performed.
CHECK
  1. The CHECK entry performs a model check only (even if the -analysis run option is used).
  2. If this keyword is present, only the subroutines which read in the input files are executed. A report that provides information on errors in the model and the memory and disk space requirements is given.
  3. Useful for large runs since the amount of memory and time required to perform this function is very small.
