CMBEAMM
Bulk Data Entry Defines a beam element for multibody dynamic solution sequence without reference to a property entry based on markers.
CMBEAMM | EID | MID | M1 | M2 | L | ||||
A | I1 | I2 | J | K1 | K2 |
CMBEAMM | 1 | 2 | 123 | 125 | 0.0 | 0.0 | 1.0 | 5.0 | |
100.0 | 833.3 | 833.3 | 1485.3 |
EID | Unique element
identification number. (Integer > 0) |
MID | Material identification
M1 | Marker identification
M2 | Marker identification
L | Undeformed length along
the X-axis of the beam. (Real) |
A | Area of the beam
cross-section. (Real) |
I1 | Area moment inertia in
plane 1 about the neutral axis. No default (Real > 0.0) |
I2 | Area moment inertia in
plane 2 about the neutral axis. No default (Real > 0.0) |
J | Torsional
constant. (Real > 0.0) |
K1, K2 | Area factor for
shear. Default = 0.0 (Real) |
- The X-axis of the markers M1 and M2 should always be along the axis of the beam.
The moments of inertia are defined as:
(1) The beam coordinates must be aligned with the principal axes of the cross-section.|1=/zz=∫y2dA|2=/yy=∫Z2dA - The transverse shear stiffness in planes 1 and 2 are (K1)AG and (K2)AG, respectively. If a value of 0.0 is used for K1 and K2, the transverse shear flexibilities are set to 0.0 (K1 and K2 are interpreted as infinite).
- This card is represented as a bar element in HyperMesh.
