CMBUSHM
Bulk Data Entry Defines a bushing element without reference to a property entry based on markers.
CMBUSHM EID   M1 M2
    "K" K1 K2 K3 K4 K5 K6
    "B" B1 B2 B3 B4 B5 B6
    "P" P1 P2 P3 P4 P5 P6
CMBUSHM 1   12 13
    K 100 100 100 1 1 1
    B 1 1 1 0.1 0.1 0.1
    P 0 0 0 0 0 0
EID Unique element identification number.
(Integer > 0)
M1 Marker identification number.
(Integer > 0)
M2 Marker identification number.
(Integer > 0)
K Stiffness specifier.
K1, K2, K3 Translational stiffness.
(Real)
K4, K5, K6 Rotational stiffness.
(Real)
B Damping specifier.
B1, B2, B3 Translational damping.
(Real)
B4, B5, B6 Rotational damping.
(Real)
P Preload specifier.
P1, P2, P3 Translational preload.
(Real)
P4, P5, P6 Rotational preload.
(Real)
