CMBUSHT
Bulk Data Entry Defines a bushing element without reference to a property entry.
CMBUSHT | EID | G1 | G2 | X1, G3 | Y1 | Z1 | |||
"K" | K1TID | K2TID | K3TID | K4TID | K5TID | K6TID | |||
"B" | B1TID | B2TID | B3TID | B4TID | B5TID | B6TID | |||
"P" | P1 | P2 | P3 | P4 | P5 | P6 |
CMBUSHT | 4 | 1 | 2 | 1.0 | 0.0 | 0.0 | |||
K | 100 | 100 | 100 | 1 | 1 | 1 | |||
B | 1 | 1 | 1 | 1 | 1 | 1 | |||
P | 0 | 0 | 0 | 0 | 0 | 0 |
EID | Unique element
identification number. (Integer > 0) |
G1 | Grid point identification
G2 | Grid point identification
G3 | Grid point identification
number to optionally supply X1,
Y1, and Z1 in conjunction
with G1. (Integer > 0) |
X1, Y1, Z1 | Orientation vector of the
bushing. (Real) |
K | Stiffness specifier. | |
K1TID, K2TID, K3TID | Translational stiffness
TABLEDi ID. Default = 0 (Integer ≥ 0 or blank) |
K4TID, K5TID, K6TID | Rotational stiffness
B | Damping specifier. | |
B1TID, B2TID, B3TID | Translational damping
B4TID, B5TID, B6TID | Rotational damping
P | Preload specifier. | |
P1, P2, P3 | Translational preload. | |
P4, P5, P6 | Rotational preload. |
- This card is represented as a spring element in HyperMesh.
