CMETHOD
Subcase Information Entry The CMETHOD command can be used to select the method for complex eigenvalue extraction.
CMETHOD = option
Argument Options Description
option <SID>
No default
SID
Set identification of an EIGC Bulk Data Entry.
  1. Only one CMETHOD entry can be defined in a subcase.
  2. A CMETHOD entry is required for Complex Eigenvalue Analysis.
  3. If present above the first subcase, it is applied to all complex eigenvalue subcases.
