CMSPDPC
Bulk Data Entry Defines a spring damper element without reference to a property entry for multibody solution sequence.
CMSPDPC EID KCID G1 G2 BCID L PF TYPE
  KINT KEID BINT BEID
CMSPDPC 3 34 223 324 0 1.0   TRANS
  AKIMA 1
EID Unique element identification number.
(Integer > 0)
KCID Stiffness curve ID.
Default = 0 (Integer ≥ 0 or blank)
G1, G2 Grid point identification number.
(Integer > 0)
B Damping curve ID.
L Unstretched length of spring damper.
Default = 0 (Real > 0.0 or blank)
PF Preload force.
Default = 0 (Real or blank)
TYPE Type.
TRANS (Default)
ROT
blank
KINT Stiffness Interpolation type.
LINEAR
CUBIC
AKIMA (Default)
(Character)
KEID MBVAR ID for independent variable ID for stiffness.
Default = Deflection (Integer ≥ 0 or blank)
BINT Damping Interpolation type.
LINEAR
CUBIC
AKIMA (Default)
(Character)
BEID MBVAR ID for independent variable ID for damping.
Default = Velocity (Integer ≥ 0 or blank)
  1. The spring damper force is along the line segment connecting the grids G1 and G2.
  2. The positive preload force is a stretching force.
  3. This card is represented as a spring element in HyperMesh.
