CMSPDPE
Bulk Data Entry Defines a spring damper element without reference to a property entry for multibody solution sequence.
CMSPDPE | EID | KEID | G1 | G2 | BEID | L | PF | TYPE |
CMSPDPE | 3 | 3 | 223 | 324 | 4 | 1.0 | TRANS |
EID | Unique element
identification number. (Integer > 0) |
KEID | MBVAR ID for stiffness
expression. Default = 0 (Integer ≥ 0 or blank) |
G1, G2 | Grid point identification
BEID | MBVAR
ID for damping expression. Default = 0 (Integer ≥ 0 or blank) |
L | Unstretched length of
spring damper. Default = 0 (Real > 0.0 or blank) |
PF | Preload force. Default = 0 (Real or blank) |
TYPE | Type.
- The spring damper force is along the line segment connecting the grids G1 and G2.
- The positive preload force is a stretching force.
- This card is represented as a spring element in HyperMesh.
