CMSPDPM
Bulk Data Entry Defines a spring damper element without reference to a property entry for multibody solution sequence based on marker.
CMSPDPM | EID | K | M1 | M2 | B | L | PF | TYPE |
CMSPDPM | 3 | 34.5 | 223 | 324 | 0.0 | 1.0 | TRANS |
EID | Unique element
identification number. (Integer > 0) |
K | Stiffness value. Default = 0.0 (Real or blank) |
M1, M2 | Marker identification
B | Damping value. Default = 0.0 (Real or blank) |
L | Unstretched length of
spring damper. Default = 0 (Real ≥ 0.0 or blank) |
PF | Preload force. Default = 0 (Real or blank) |
TYPE | Type.
- The spring damper force is along the line segment connecting the marker M1 and M2.
- The positive preload force is a stretching force.
- This card is represented as a spring element in HyperMesh.
