CMSPDPT
Bulk Data Entry Defines a spring damper element without reference to a property entry for multibody solution sequence.
CMSPDPT EID KTID G1 G2 BTID L PF TYPE
CMSPDPT 3 3 223 324 4 1.0   TRANS
EID Unique element identification number.
(Integer > 0)
KTID TABLEDi ID for stiffness.
Default = 0 (Integer ≥ 0 or blank)
G1, G2 Grid point identification number.
(Integer > 0)
BTID TABLEDi ID for damping.
L Unstretched length of spring damper.
Default = 0 (Real > 0.0 or blank)
PF Preload force.
Default = 0 (Real or blank)
TYPE Type.
TRANS
ROT
blank
Default: TRANS
  1. The spring damper force is along the line segment connecting the grids G1 and G2.
  2. The positive preload force is a stretching force.
  3. This card is represented as a spring element in HyperMesh.
