CNTNLSUB
Subcase Information Entry The CNTNLSUB command can be used to continue a nonlinear solution from a preceding nonlinear subcase, and thus create complex loading sequences.
CNTNLSUB=option
Argument | Options | Description |
option | <YES,
NO, SID> Defaults: If CNTNLSUB does not exist in the input file, the default is NO. If CNTNLSUB exists in the input file, but a value is not specified, the default is YES. |
- This command applies only to nonlinear subcases.
Nonlinear subcases may only be continued from other nonlinear subcases of the same analysis type. That is, Small Displacement Nonlinear Analysis subcases (ANALYSIS=NLSTAT) may only be continued from other Small Displacement Nonlinear Analysis subcases, Nonlinear Transient Dynamics Subcases (ANALYSIS=EXPDYN) may only be continued from other Nonlinear Transient Dynamics Subcases, and Large Displacement Nonlinear Analysis Subcases (PARAM, LGDISP, 1) may only be continued from other Large Displacement Nonlinear Analysis Subcases.
- Only one CNTNLSUB entry can be defined for each subcase.
- If CNTNLSUB = option is present above the first subcase, it is applied to all nonlinear subcases. (CNTNLSUB = SID is only allowed within a subcase).
- CNTNLSUB is mostly relevant in path-dependent problems, such as plasticity or gap/contact analysis with friction/stick. In these problems, subcase continuation can be used to create complex loading paths that will typically produce very different results than simple proportional loading of a single subcase. CNTNLSUB also affects the convergence history and, to some extent, the results in problems that typically are not path-dependent, such as gap/contact analysis without friction.
- If displacement boundary conditions specified by zero or non-zero SPC or SPCDs which exist in preceding subcase (Subcase 1) are removed in the subsequent nonlinear subcase (Subcase 2), then they are converted into equivalent internal forces at the beginning of the subsequent continued subcase (Subcase 2). These internal forces are ramped down gradually. However, in subcase 2, the SPCFORCE output itself will be reset to zero immediately for these boundary conditions. If the deformed shape resulting from the preceding subcase should be unchanged in Subcase 2, then the D field should be set to F on the SPC or SPCD entries. Retaining the deformed shape by setting the D field to F on the SPC/SPCD entry is supported for both analysis and optimization.
