CNTSTB
Bulk Data Entry Defines parameters for stabilization control of surface-to-surface contact and large displacement node-to-surface contact.
A CNTSTB Bulk Data Entry should be referenced by a CNTSTB Subcase Information entry to be applied in a particular subcase globally.
CNTSTB | ID | APSTB | LMTGAP | S0 | S1 | ||||
SCALE | TFRAC |
CNTINT | CTID | APSTB | LMTGAP | SO | S1 | ||||
SCALE | TFRAC |
GAPINT | PID | APSTB | LMTGAP | SO | S1 | ||||
SCALE | TFRAC |
CNTINT and GAPINT continuation lines can coexist in one CNTSTB card. CTID and PID can be identical in one CNTSTB card, as well.
CNTSTB | 99 | NO | |||||||
CNTINT | 51 | YES | |||||||
0.01 | |||||||||
CNTINT | 52 | YES | |||||||
10.0 | 0.01 | ||||||||
GAPINT | 52 | YES | |||||||
1.0E4 | 0.25 | ||||||||
GAPINT | 58 | YES | 1.0 | 0.001 | |||||
1.0E4 | 0.05 |
ID | Each
CNTSTB Bulk Data Entry should have a unique
APSTB | Head flag indicating if
contact stabilization is activated.
Note: All the fields following
APSTB should be blank, if
APSTB is set to
NO.
LMTGAP | Contact opening threshold
for stabilization. Stabilization becomes zero when contact opening
is greater than or equal to this value.
(Real > 0.0 - specified threshold value) |
S0 | Scale factor for
stabilization coefficient at the start of a subcase. Default = 1.0 (Real ≥ 0.0) |
S1 | Scale factor for
stabilization coefficient at the end of a subcase. Default = 0.0 (Real ≥ 0.0) |
SCALE | Stabilization coefficient
scale factor. Default = 1.0 (Real ≥ 0.0) |
TFRAC | Factor for scaling
tangential stabilization with respect to normal
stabilization. Default = 0.1 (Real ≥ 0.0) |
CNTINT | Defines the start of a continuation line used to specify another set of stabilization parameters, which overrides the set of parameters defined above, for a specific contact interface (CTID). It can be repeated as required. | |
CTID | Contact interface
GAPINT | Defines the start of a continuation line used to specify another set of stabilization parameters, which overrides the set of parameters defined above, for specific CGAP/CGAPG elements (PID). It can be repeated as required. | |
PID | Gap property
- The CNTSTB Bulk Data Entry is selected by the CNTSTB Subcase Information Entry.
- When APSTB is YES, the contact
normal stabilization stiffness
KnormalCSTB
is calculated as:
(1) KnormalCSTB={SCALE⋅f(t*)⋅KCREFif contact opening<LMTGAP0if contact opening≥LMTGAPWhere, KCREF is automatically calculated reference stiffness (10-5 times the contact penalty stiffness) for contact stabilization, and f(t*) is the time-dependent scale factor.
For time, t in a subcase, t* is calculated as:(2) t*=(t−t0)/(t1−t0)Where,- t0
- Time at the start of the subcase
- t1
- Time at the end of the subcase
f(t*) is calculated using S0 and S1 as f(t*)=S0⋅(1−t*)+S1⋅t* .
tangent stabilization stiffness
KtangentCSTB
is calculated as:
(3) KtangentCSTB=TFRAC⋅KnormalCSTB - The defaults and priority information in conjunction with PARAM,EXPERTNL,CNTSTB for different contact types are:
Table 1. Contact Stabilization. Stabilization is not applicable to FREEZE or TIE Contact Model without LGDISP Analysis Model with LGDISP Analysis N2S S2S/CGAP/ CGAPG
N2S for LGDISP S2S/CGAP/ CGAPG
PARAM,EXPERTNL,CNTSTB Effective 2 Effective 1 Effective 1 Effective 1 CNTSTB (Bulk card referenced by Subcase Entry) Ineffective Effective Effective Effective PARAM,EXPERTNL,CNTSTB + CNTSTB (Bulk card referenced by Subcase Entry) Stabilization with the PARAM is effective 2 For the subcase that references CNTSTB (Bulk Data), stabilization with the Bulk card is effective; For other subcases, stabilization with the PARAM is effective. 1 For the subcase that references CNTSTB (Bulk Data), stabilization with the Bulk card is effective; For other subcases, stabilization with the PARAM is effective. 1 For the subcase that references CNTSTB (Bulk Data), stabilization with the Bulk card is effective; For other subcases, stabilization with the PARAM is effective. 1 - When both CGAP/CGAPG elements and contact elements appear in a model together with CNTSTB applied globally, the global damping stabilization will not be applied on the CGAP/CGAPG elements, unless GAPINT is defined in CNTSTB card. When only CGAP/CGAPG elements appear in a model with CNTSTB applied globally, the global set of damping stabilization parameters will apply on the CGAP/CGAPG elements.
- This card is represented as a load collector in HyperMesh.
