For Nonlinear Analysis, the contact status can change during the run, which implies that
the contact element stiffness can switch between the closed (KA) and open
(KB) values.
For nonlinear analysis, the contact condition does not change within an iteration, during
reevaluation at the end of each iteration, if the contact condition for some or all
contact elements has changed, the revised contact condition is used for the subsequent
iteration. Therefore the over the course of a nonlinear analysis the contact can open or
close multiple times. The Contact stiffness is KA when closed and
KB when open, similar to the linear case; however, since the
contact status can change, the Contact element force is not tensile, with slope
KA, when the contact moves from closed to open status. When the
contact is open, the normal stiffness is essentially zero (very small slope
KB to avoid singularities). The closure of the contact element
increases the stiffness value to KA. Figure 1. Penalty-based Contact Element Force-Displacement Curves for Nonlinear
Analysis
The STIFF field on the PCONT Bulk Data Entry can be used to
control the stiffness of the contact interface. The AUTO,
SOFT, and HARD options are available for automatic
predefined stiffness setting. Additionally, a positive real value can be specified to
directly prescribe the contact stiffness value. If a negative real value is specified,
then it scales the STIFF=AUTO value by the specified
scaling factor.
