CROD
Bulk Data Entry Defines a tension-compression-torsion element (ROD) of the structural model.
CROD | EID | PID | G1 | G2 |
CROD | 12 | 13 | 21 | 23 |
EID | Unique element identification
number. (Integer > 0) |
PID | A PROD property entry
identification number.
Default = EID (Integer > 0 or <String>) |
G1, G2 | Grid point identification
numbers of connection points. (Integer > 0; G1 ≠ G2) |
- Only one ROD element may be defined on a single entry.
- String based labels allow for easier visual identification of properties, when being referenced by the elements cards. For more details, refer to String Label Based Input File in the Bulk Data Input File.
- This card is represented as a rod element in HyperMesh.
