CTUBE
Bulk Data Entry Defines a tension-compression-torsion element (TUBE) of the structural model.
CTUBE EID PID G1 G2
CTUBE 12 13 21 23
EID Unique element identification number.
(Integer > 0)
PID A PTUBE property entry identification number.
(Default = EID, Integer > 0)
G1, G2 Grid point identification numbers of connection points.
(Integer > 0; G1G2)
  1. Only one TUBE element may be defined on a single entry.
  2. CTUBE data is converted to CROD data as it is read. PTUBE data is converted into PROD data.
  3. This card is represented as a rod element in HyperMesh.
