CVISC
Bulk Data Entry Defines a viscous damper element.
CVISC EID PID G1 G2
CVISC 2 64 12 63
EID Unique element identification number.
No default (Integer > 0)
PID A PVISC entry identification number.
Default = EID (Integer > 0)
G1, G2 Geometric grid point identification numbers of connection points.
  1. G1G2.
  2. Only one viscous damper element may be defined on a single entry.
  3. Viscous damper elements are ignored in heat transfer analysis.
  4. This card is represented as a spring element in HyperMesh.
