DEFORM
Subcase Information Entry The DEFORM command can be used to select an element deformation set.
DEFORM = option
Argument Options Description
option <SID>
SID
Set identification of a DEFORM Bulk Data Entry.
  1. Only one DEFORM entry can be defined for each subcase.
  2. If present above the first subcase, it is applied to all linear static, linear buckling, and nonlinear quasi-static (Gap/Contact) subcases.
