DENSRES
I/O Options EntryThe DENSRES command can be used in the I/O Options section to control the frequency of output of design results (density, shape, or thickness).
DENSRES = frequency
Argument | Options | Description |
frequency | <FIRST, LAST,
FL, ALL,
N> Default = ALL |
Optimization results are output for:
- This output control is ignored if OUTPUT, DESIGN is present.
- When the DENSRES command is not present, results are output for all iterations.
- From 10.0 onwards, it is recommended to use the OUTPUT I/O Option Entry to control this output.
