DESGLB
I/O Options and Subcase Information Entry The DESGLB command can be used in the I/O Options section, before the first subcase statement, to select a constraint set that is not subcase dependent.
DESGLB = integer
- The constrained response referenced by the DESGLB constraint selection must not be subcase dependent.
- Only one DESGLB entry can be defined in the I/O Options section for the entire model.
- This entry is represented as an optimization constraint in HyperMesh.
