DESSUB
Subcase Information Entry The DESSUB command can be used in the Subcase Information section, within a subcase definition, to select a constraint set that is subcase dependent.
DESSUB = integer
- The constrained response referenced by the DESSUB constraint selection must be subcase dependent.
- This entry is represented as an optimization constraint in HyperMesh.
