DESVAR
Subcase Information Entry The DESVAR command can be used to select a set of design variables for use in an optimization run.
DESVAR = option
Argument | Options | Description |
option | <ALL, SID> |
- Only one DESVAR command may appear in the Subcase Information section and should appear before the first SUBCASE statement.
- The DESVAR command is optional. If it is absent, all DESVAR Bulk Data Entry will be used.
- DESVAR Bulk Data Entry that are not selected by this command are frozen at their initial values (that is same as setting XINIT=XLB=XUB) and all referenced properties will still be governed by the DESVAR settings.
