DESVARG
Bulk Data Entry Defines an override for design variable settings.
DESVARG | ID | INIT | LB | UB | SET |
ID | Identification
number. No default (Integer > 0) |
INIT | Overrides the initial
value setting for affected design variables.1 Default = blank (UB, LB, blank, Real or ANALYSIS) |
LB | Overrides the lower bound
setting for affected design variables. Default = blank (blank or Real) |
UB | Overrides the upper bound
SET | Defines the design
variables that are affected by this DESVARG
entry. Can either be the keyword ALL or the
SID of a SET of type
DESVAR. Default = ALL (ALL or Integer) |
- If any of INIT, LB or UB are left blank, then no override is applied to the corresponding field on affected DESVARs.
- If INIT is defined as
LB, then for all affected DESVAR
entries the initial value is set to the lower bound setting.
Likewise if INIT is defined as UB, then for all affected DESVAR entries the initial value is set to the upper bound setting.
If, INIT is defined as ANALYSIS, then for all affected DESVAR entries the initialization is accomplished based on the corresponding analysis properties.
Limitations for the ANALYSIS mode of initialization in the INIT field:When one of the three limitations occurs, a warning is issued and the Design Variable is initialized based on the DESVAR card.
- Multiple DESVARGs are allowed (DESVARGs are processed in the order of input).
- If the bounds are invalid after DESVARG is applied, then an error will occur.
- This card is represented as a control card in HyperMesh.
