DIM
Bulk Data Entry Defines a link between a DIM# field on a PBARL or PBEAML property and either the thickness on a PSEC definition or the y or z coordinate on a GRIDS definition; it is used in the definition of arbitrary beam cross-sections.
DIM DIMID T PID
Alternate Format
DIM DIMID G GID COORD
DIM 1 T 10
DIMID Dimension identification number. The number of a cross-section dimension field on a PBARL or PBEAML property definition.
No default (Integer > 0)
T Thickness flag. Indicates that the dimension definition is related to a PSEC thickness.
PID A PSEC definition identification number.
G Grid flag. Indicates that the dimension definition is related to a GRIDS coordinate.
GID A GRIDS definition identification number.
COORD Coordinate.
Y
Z
No default
  1. DIMID may be repeated in a section definition, but a PSEC thickness or a GRIDS coordinate must not be mentioned on more than one DIM entry within a section definition.
  2. This entry is only valid when it appears between the BEGIN and END statements.
