DOPTPRM, BKLOCAL1
Bulk Data Entry Determines the buckling zone of the model.
Parameter Values Description
BKLOCAL1 <0.0 ≤ Real ≤ 1.0>
Default = 0.5
Any grids with eigenvectors greater than the specified value (BKLOCAL1*largest eigenvector) are considered as the buckling zone.
The constraint bound for local mode will be specified in 6th field of DCONSTR.
