DOPTPRM
Bulk Data Entry Defines design optimization parameters by overriding the defaults.
DOPTPRM PARAM1 VAL1 PARAM2 VAL2 PARAM3 VAL3 PARAM4 VAL4
  PARAM5 VAL5 etc.
DOPTPRM MINDIM 10.0 OBJTOL 0.01
Field Contents
PARAMi Parameter name. See below for valid names.
VALi Parameter value.
(Real, Integer, or Label)
The available parameters and their values are listed below (click the parameter name for detailed parameter descriptions).
  1. Some of the parameters may also be defined as separate entities in the I/O section of the deck, using the Previous (OS3.5) Input Format. Only one definition is allowed.
  2. This card is represented as an opticontrol in HyperMesh.
