DOPTPRM, DELSIZ
Bulk Data Entry The initial fractional move limit for size design variables.
Parameter Values Description
DELSIZ Real > 0
Default = 0.5
Only the initial value of the move limits can be set. Move limits are automatically adjusted to enhance iterative stability and convergence speed.
The move limits for subsequent iterations may not be greater than this initial move limit.
