DRAPE
Bulk Data Entry Defines the draping data for plies used in ply-based composite definition.
DRAPE ID
  DTYPE1 DID1 T1 THETA1
  DTYPE2 DID2 T2 THETA2
  etc
ID Unique draping identification number.
No default (Integer > 0)
DTYPE# Entity type.
ELEM
SET
ALL
No default
DID# Entity number. Must refer to an element (for ELEM) or SET (for SET) Bulk Data Entry. Must be blank for ALL.
No default (Integer > 0 or blank)
T# Thinning factor.
Default = 1.0 (Real or blank)
THETA# Angle variation.
Default = 0.0 (Real or blank)
